Rick_Jay
Apr 10, 2021Explorer II
I echo johnsonbert's recommendation for stainless steel hardware.
If I might make another suggestion: Once you are sure you have the hardware in the proper location and everything is aligned properly, I might recommend that you put some Loctite Purple (or possibly Loctite Blue) on the threads of the screws. I'd remove each nut, one at a time and put a dab of the Loctite on it so you don't cause anything to misalign. Then, with the Loctite on, snug each one up securely.
Or, if you're comfortable with a rivet gun, that's fine too.
~Rick
~Rick
38,780 PostsLatest Activity: Jul 20, 2026
