hal1phx
Dec 21, 2014Explorer
Docdoor wrote:
hal1phx
What make and model do you have?
I replaced my Sharp R-1850A Convection with a Sharp R-18800LS
I determined that they used the same mounting bracket, hence would attach to my existing mounting plate. I used the following web site https://partstore.com/SearchResults.aspx?q=r1850&SearchTerm=True and noted that they both used the same unit mounting bracket part # FANGTB003MRY0 . if you go to the site click on the "unit mounting bracket" then click on "compatible models"
We're replacing a GE Profile JVM 1490 SD oo3 1.5
Two issues ... the first being the long bolts in the front corners running up thru the top into the ceiling (no upper cabinets) .. and having a door hinge that keeps the door flush with the unit when the door opens. we have a cabinet along side the unit
38,782 PostsLatest Activity: Sep 10, 2026
