Harvard
May 26, 2018Explorer
You have too little +caster for highway speeds.
Ford ships these E350/E450 Cutaways off the assembly line
with +3 to +4 degrees of Caster. Those settings are
OK for city driving BUT you want to have +5 to +6 degrees
of Caster for highway driving, OTHERWISE:
POPULAR MECHANICS MAY 1973:
START QUOTE:
If too little caster exists, the car will wander and weave,
thus necessitating constant corrections in steering.
END QUOTE:
There are at least two ways to increase the effective
runtime caster:
1. Decrease the tire inflation pressure to the required
minimum for load (to increase Pneumatic Trail), and or
2. Increase the caster angle during an alignment
(to increase caster trail).
If you find an improvement in reducing the tire pressure
you will be amazed what it is to add +2 degrees of caster. IMO.
The specified range of Caster for the E350/E450 is
from +1.5 to +7.0 degrees. As you can see
almost any possible setting is "within spec"
for the "tweak the toe and you are good to go"
alignment services. Stay away from Ford
dealerships and have it done at a "good"
truck front end shop".
Caution, "You may need to teach a new dog old tricks."
START QUOTE:
END QUOTE:
runtime caster:
38,766 PostsLatest Activity: Jan 10, 2026
