Harvard
May 28, 2018Explorer
ron.dittmer wrote:
Three things will help you with your 2014 E450 chassis. If after you do all three and you still are not satisfied, then there is another list. But do these first, then move on from there.
1) The right tire pressure with consideration to the weight on your front tires.
2) A front wheel alignment done with your rig loaded up as if on a trip
3) A heavy duty steering stabilizer (which you are researching)
Our 24 foot rig with 158" wheel base has a Safe-T-Plus steering stabilizer and we like it very much.
As you have learned, the stock steering stabilizer provided by Ford is ineffective.
The worst handling class-C rigs are the shortest ones with huge rear over-hangs behind the rear axle. The longer the rig, the more stable it is on the road. The sweet spot seems to be an extended wheel base around 200" and 26-27 over-all length.
But, do the list one at a time. Otherwise, the "clamp on" sales force would like nothing better then take credit for the improved stability that was actually due to an increase in caster and not their gadget. Just saying! I find the caster seeds I plant take years to germinate so I need to plant lots of them. :B
38,763 PostsLatest Activity: Dec 25, 2025
