Desert_Captain
Jun 28, 2023Explorer III
1995brave wrote:
I have a 2018 Nexus 24P and have been dreading doing my battery compartment. Seeing your results has given me hope again and as soon as the temp decides to drop I'll get started on mine. Mine is rusted so bad I could only pull the tray half way out. I bought mine used in 2021 and the dealer replaced the batteries.
Because of the weight {in my case, 128#} the tray is not designed to slide all of the way out, about half way is as far as it goes. Disconnect and remove the batteries and then you will have access to the tray and slider.
With the batteries removed slide the tray as far back as it will go. Tilt the forward {outside} end of the tray up about 30 degrees and pull forward a about an inch. Look at the second pic in my post and you will see the opening slots on either side of the slider base. The bolts on the sides should lift out of the slider track and the slider and tray will lift out as one piece.
Hope this helps, feel free to PM me if you have any questions.
Good luck.
:C
