BFL13
Dec 12, 2018Explorer II
I have the RTH111 as well now. Use R and W and leave the jumper in like DrewE said. Not sure about red and white wires. With ours, it is two blue wires to the thermostat, where the blue wire is connected and disconnected by the thermostat. With the two blues it doesn't matter which goes where
Easy to check if you have the right two wires- just connect the red and white ends to see if the furnace then comes on.
38,769 PostsLatest Activity: Apr 04, 2026
