Scott___Jill's avatar
Scott___Jill
replcing mirror glass
I have a 1999 Fleetwood pace arrow on the driver side mirror with heat and remote the convex mirror ( bottom ) is broke dose any one know if you can just buy that bottom piece or just the mirror glass ?
  • Your profile doesn't mention where you are, but if you're close to Mexico or travel there, many glass shops down there can make you a new fitted mirror and some can make the convex mirror, all for just a few bucks.
    I got two replacement mirrors from a drawing I made at a Mazatlan glass shop for under $12 USD. A taxi driver knew about the place. I did the install of one replacement mirror into the frame myself as the glass shop didn't do that, but it was fairly easy. (The other mirror was a spare, in case I hit another street sign on the freeway again).
    The heater element was a sheet of heating wire attached to a sticky sheet that I carefully pealed off the smashed original mirror...it stuck right onto the back of the new mirror no problem. The new mirror I held in with a bead of silicone surrounding it on the edge. Not exactly like the original, but it worked.
    No problem with it for several years afterwards either.
  • Most mirrors have replaceable glass. Take a look at the mirror and determine the manufacturer (such as Velvac) and model number and then contact the manufacturer for replacement parts.
    Doug
  • Call Fleetwood, they will give you the manufacturer's name and contact details.
    And yes, you can just buy the convex mirror as a separate item.
