Drect's avatar
Drect
Require a new driver's side wiper pivot mechanism
Good day, I'm new to this forum and looking for some help. I have a 2006 Holiday Rambler Scepter, 41ft. The driver's side wiper pivot mechanism is stripped, so the wiper, at will, slides off the drivers side of the coach when it does decide to work. The original P/N is 300678. Does anyone know where I might purchase one, I'm thinking aftermarket likely unless someone knows of some OEM ones around somewhere.
Thanks in advance
Dan
  • Wiper Technology 833-947-3771, used to be Diesel Equipment the OEM for your windshield wipers.
  • Drect, I would suggest you go to IRV2/forums/f115/ which is the Monaco site on IRV2 and I am sure someone there will be able to help you. Good luck Don
  • Well Mr. MountainAir05 , Thanks. It may be a "Double Post", but as you can see I said I was new here and if I could have found what I was looking for before I would have read it. Wanker. At least Chum Lee was kind enough to at some info that would definitely help. It's too bad right off the bat some dick like you shows up. This was a short lived visit to this forum.
    Thanks in advance
    Dan
    Dan: Depending on who the chassis manufacturer of your coach was, the wiper pivot may have been supplied by the chassis manufacturer or from the coach manufacturer. At 41 ft., I'm assuming it's a diesel pusher, but, it would be best if you include that information in your initial post if you want accurate useful information.
    Chum lee
