FIRE_UP
May 22, 2016Explorer
mackr wrote:
Anyone around Raleigh N C done there's or had it done.thanks
I'm going to assume you mean to seal all the vents, cap edges, plumbing vents etc. and not re-seal the entire fiberglass roof, correct? If so, it's in all reality, very simple. That is of course unless there's something prohibiting from you getting on the roof. If so, then, yep, you'll have to contract that out. But, if not, I simply use a heat gun, remove all the sealant around all the vents etc. and wipe things down with alcohol and, re-apply Dicor self leveling sealant. Works like a charm and really does a bang-up job on sealing every seam, edge, screw head, antenna base(s) and more.
Scott
