SHRED
Dec 27, 2018Explorer
Resealing the hatches
I was going to scrap off and use a wire wheel on the old cracked sealant, clean with denatured alcohol, then apply Dicor lap sealant. Am I on the right track?
CharlesinGA wrote:
Keep the wire wheel away from anything. It will do more damage than good. On aluminum you stand the chance of starting corrosion when the steel particles from the brush become embedded in the aluminum. Otherwise it will chew the aluminum to shreds.
Charles
