CyflopperExplorerJan 15, 2019reset button?Above the drivers area I have an entertainment center. I plugged a vacuum in to the plug where the tv/vcr etc gets plugged into and apparently blew a fuse...circuit...default. Any ideas how to reset...Show More
wildtoadExplorer IIJan 15, 2019Does the entertainment center run off inverter? If so check inverter fuse / breaker.
Related ContentReset button/slideoutBackwards buttonsReset of AladinMicrowave buttonsCan you trust the test & reset buttons on a GFCI?
