chili_s_trip
Aug 24, 2013Explorer II
TechWriter wrote:RayChez wrote:
If you are going to have full hook up's all your life, THEN! I can see a residential refrigerator.
If memory serves, Full Hook ups = Electricity, Sewer, and Water. You only need the first one for a residential fridge.RayChez wrote:
But if I was to dry camp a lot . . .
Do you dry camp a lot? I'll bet not.RayChez wrote:
I guess I have been one of the lucky persons with the Norcold 1200LRIM because it has been a very good refrigerator for the last ten years . . .
I don't think you're lucky at all. My Dometic NDR1292 is 12 years old and has performed admirably. I think the same is true of all absorption fridges. However, I'll bet that few if any residential fridges will last that long in an RV.
The fire issue has been overblown (no pun intended). Blaming all models of Dometic & Norcold absorption fridges for the bad design of a few models is like never driving a car again because of the Ford Pinto.RayChez wrote:
The freezer has always kept the ice cream frozen solid and the steaks solid like a rock. So like I said, I must be one lucky guy.
However, the reason I'm going with a residential is because of the fridge, not freezer, temperature. The temperature in a refrigerator should always be 40 degrees or below. Otherwise, you're endangering your health. It's as simple as that to me.
After trying numerous ways (fans and an adjustable thermistor) to keep the temp down in my old Dometic, the fridge temp climbs -- and stays -- past 40 degrees all too often.
I'd suggest buying a good fridge thermometer like the Taylor Classic 5924 and keep track of your Norcold.
Thank you for your imput but I use thermometers in freezer and refer and keep close eye on the temps in this summer weather. The rig sits with the refer sun side and maintains 0-3 degrees and 36-39 with the temp control on 3 to conserve propane. My fridge compartment thermometer show history of high/temps. Good luck!
