down_home
Aug 24, 2013Explorer II
chili's trip wrote:John S. wrote:
I am goingto run my genset for the coffee maker and the microwave anyway so it will bulk charge the batteries then. I have friends who have put up soar and do not need to run the genset much at all. It is there and simple so I run it when it needs to be run. This coach does not have the same soar setup I ad on my last coach but my next coach will be designed with it in mind and will not require any real genset run time other tan baking in the microwave or the washing machine.
I run my gen sometimes for coffee and microwave. Maybe 15 min max. Doesn't seem be enough enough time to bring batteries to full charge. I have using dometic reefers for 8 years with no problems and complete independence from the grid and no p o neighbors. I don't get it?
Most coaches now have auto gen start, ours don't though. Shouldn't be any problem when load management system is set properly? It should kick on when the batteries get low and bring them up to full charge. It won't matter if you run the gen with the batteries at full charge. The load center sends excess to ground?
38,782 PostsLatest Activity: Sep 10, 2026
