RayChez wrote:
Ivylog wrote:
I am in the process of installing a Whirlpool WRT771RWYB 21 cu ft as it's 32.5"W X 34" D and it's height is only 65.5". By cutting out the thin board at the top of the hole that the 1200 uses to hold it in, it should fit without any other changes. It's the only refer I've found that does not require major modifications as most are 69+" high. Sears Outlets in Egin,IL still has it in white and Naperville, IL in black.
So does the new fridge stick out seven inches further then the Norcold 1200 LRIM? WOW! I do not think I would want another fridge to stick out that much.
No Ray, it won't. It may be 7" deeper, but it doesn't require the room behind it the Norcold does.
Take a look at the pictures in the link Dennis provided and you'll see.
Also read Ivylogs post again - the
bold parts above.
