TNGW1500SE
Jul 14, 2016Explorer
I have a thermometer with a transmitter installed inside my residential style fridge so I can keep tabs on the temp from the dash while driving without opening the door. That way if it gets warm, I can start the generator. I often see a lot of variation in the temps even when plugged in at a campground. It might be 35 and then an hour later, it's 41 degrees. I think most people don't "watch" the fridge as close as I do and it's probably just normal and since I'm not refrigerating the cure for cancer, I don't worry about it much . In my old RV style fridge, I installed a 12 volt PC fan. That might help you "mix" the air and "balance" out the temps.
I'd also try just taping the door shut to make sure that wasn't an issue while traveling.
38,766 PostsLatest Activity: Jan 10, 2026
