pianotuna
Sep 25, 2018Nomad III
$2 per watt for DIY. That is up since the tariffs were instituted.
The biggest cost is "getting it wrong". For example the solar charge controller I have is maxed out. Replacing it is far more expensive than adding panels.
Two https://www.solarblvd.com/products/12-volt-240-watt-solar-panel-kit/ would be 480 watts, total cost for all materials $600.00. Add a MSW Cobra 2500 watt inverter for $200.
Based on 5 solar "hours" per day the harvest would be 2.5 kwh. That is enough to run a residential fridge.
Solar Blvd suggests such a system would produce about 77 kwh per month.
Gjac wrote:
If one were to add the solar that others like pianotuna talks about to maintain the batteries, I see folks advocating between 400 - 1000 watts of solar what would those cost be?
38,769 PostsLatest Activity: Jun 25, 2013
