msturtz
Jul 21, 2016Explorer
We have a residential refrigerator and have set the temperature as cold as it will go without freezing the refrigerator food. This is due to my prior experience in foodservice. But back to the point. Don't install another inverter you will use more energy. If you do anything add more battery capacity. Depending on the size of your inverter you may need to install a larger inverter. Keep in mind that standard inverter / converters actually produce "Modified sine wave" or "stepped square wave" power. This is very poor power to run motors on and they consume more power. You may wish to upgrade your inverter / converter to a pure sine wave inverter.
38,780 PostsLatest Activity: Nov 24, 2017
