theoldwizard1
May 24, 2020Explorer II
First, I am 100% in favor of compressor refrigerators, be they 120VAC or 12VDC. They just work better, especially in hot weather.
A pair of Group 27 "dual purpose" batteries will give you about 180 Ah of power. A pair of 6V golf cart batteries will give you about 225 Ah of power, likely will last longer and their replacement will cost less !
A 1000W inverter may or may not adequate for your refrigerator, depending on the model. Some are very efficient, some are not. BUYER BEWARE ! Do your homework !
Sadly, RV manufacturers are SEVERAL years behind the "technology" curve. You would be better off with a with a inverter/charger/automatic transfer switch and just a DC distribution panel, no converter. Sadly, few RV manufacturers offer this.
Not enough information ! How much solar ? How big of a generator ? If the generator has to run an A/C then it will take a lot more than "a couple of hours".
Also, do no bet on driving to recharge your batteries, unless you get a DC-DC charger.
msmith1199 wrote:
So the question, the Class B+ comes with two 12 volt house batteries and a 1000 watt inverter.
msmith1199 wrote:
I’ll also get a solar panel and controller on it. I do plan on boondock it quite a bit in the back country in Nevada. Should I have any power issues? If I run the generator a couple of hours a day plus having the solar will that keep the batteries charged?
38,770 PostsLatest Activity: Apr 12, 2026
