prstlk's avatar
prstlk
Residential Fridge
We are FT and just finished the AL CAN. After washing the rig in Fairbanks we got the dreaded "temp switch fail". We also had a new cooling unit installed 8 months ago. I would like some feedback from those dry campers who have done RES Fridge change-out. We have a 07 HR Ambassador. The house batts we have are the common 4x6v with 2 12V chassis bats.
Because we are FT we sometimes go 2/3 or more days without shore power. War Dept uses a C-Pap machine so when dry camping we must run the Gen for 2 hours am and 2 hours pm.
When dry camping how long can you go off 4 6vs, how much gen time do you run. Lots of varibles I'm sure, but input would be helpfull.
Thanks in advance
JW
FYI the entire AL Can experience has been wonderful. This trip should be on everyone's RV bucket list.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Pretty sure the C-Pap machine requires 120V so having two inverters is not going to save any energy... running one for both the refer and C-Pap machine at night will be more efficient.
  • "prstlk".....First, washing your coach most likely caused the switch to fail.....that has been reported hear several times.
    You don't provide some needed info.....what inverter do you have, size and MSW or PSW? The Samsung refers work well with MSW inverters. I did the same as "horizon36" and added a Magnum 600 watt inverter which has pass through capability. I like the idea of running the refer on it's own inverter, pus it gives you a back up.
    Many people are converting the Monaco coaches to a residential refer and most are using the original four 6 volt batteries and do fine. On my Monaco, I also added a rack above the four 6 volt batteries and added two more.
    Typically, the refer will do fine with a couple of hours of charging in the AM during breakfast and one hour in the PM.
  • We installed a Samsung RF197 last November and really love it. We have four 6 volt house batteries and 375 watts of solar. I added a separate 600 watt PSW inverter dedicated to the refrigerator which allows to shut down the main inverter and save power. We dry camp a total of about 8-10 weeks a year. I do run the generator for about an hour in the am when we're making coffee, toast and using the microwave. This is usually enough to get through the bulk mode in charging. If we didn't watch TV in the evenings our solar would just keep up with demand. I usually run the genset for an hour in the evenings to top off the batteries. I would recommend that you add 400 watts of solar and a good MPPT controller to help with your power demands.
    Go for it, you'll really like the size and convenience.
  • Ivylog's avatar
    Ivylog
    Explorer III
    What inverter/chager do you have now and how many amps charging do you get when running the generator to charge the batteries? My 2000W MSW Zantrax will only put out 60 amps charging on the generator instead of it's rated 100A. I was able to lower the house battery rack so I could add another rack and double my house battery bank and this was before I decided to go residential. With 800 AH of batteries I have to run my generator 2 hours at night and one in the morning... mainly because of poor charging rate of my Inverter/Charger. Looked at replacing the I/C with a 3000W PSW one but my remote control cable is a four wire telephone and the newer I/Cers use a Cat 5 cable.
    I would figure out how to double your battery bank and see how much charging you get from your I/C.
  • Hi,
    Add enough solar to run the fridge. Between 600 and 800 would be good. If you have deep pockets go to Lithium ion battery chemistry.
