Dutch_12078
Aug 10, 2017Explorer III
When you're figuring out the battery capacity, keep in mind that residential fridges typically cycle on less often and run shorter times than RV absorption fridges. The typical duty cycle is about 50% at standard temperatures, or about 20 minutes on then 20 minutes off. An RV fridge on propane though, will use much less battery power of course.
