DSDP_Don
Aug 10, 2017Explorer
"Papafishy"......Almost every diesel pusher and many Class A gassers now only come with residential refers. They've now been in use for about 6 years. Most everyone, even with large battery banks can get 24-36 hours running on batteries. This also includes using other electrical items in the coach. If you were to run just the refer and nothing else, you would probably get about 24 hours.
You would need a LOT of batteries and a LOT of solar to run 5-6 days. Batteries are cheap, but room and weight is an issue on a gas coach. Solar sufficient to do the job would be expensive.
As suggested above, you should be looking at going with a two way refer.
