Tinstar
Jul 16, 2016Explorer
Executive,,,, I read your write-up on your Samsaung install. You said the weight of it was around 450 lbs (loaded). I think the Samsung 17.5 cu.ft. is only 230 lbs. (actually lighter than the Norcold @244lbs). Do you have that much food with you are did you get a different model fridge? I know you're a full timer but over 200 lbs is still a lot of food.
38,769 PostsLatest Activity: Mar 31, 2026
