dougrainer
Jun 02, 2020Nomad
wborst wrote:
On our Newmar Mountain Aire, that vent allows warm air into the wet bay to prevent freezing. In the wet bay is a switch marked HEAT. When this switch is on, and the outside temperature falls below 40* and the furnace is enabled, a fan comes on that pulls warm air through this vent into the wet bay.
Sorry, That is not where Newmar PULLS the furnace air for the Wet Bay. There is a 4 inch flex duct connected to the Metal Floor Furnace Plenum and at the exit of that round hose inside is a 12 volt Fan and motor. If you look inside the storage bay and look UP you will see this tube. Doug (I Serviced and We sold Newmars from 1994 till 2008)
38,782 PostsLatest Activity: Sep 20, 2026
