dougrainer
May 14, 2018Nomad
They do not make such a door. Now, if you remove the existing awning and make it a manual awning with pull out arms, you can then open the door 180 degrees. Until they came out with electric awnings, this was never a problem. Depending on the model and brand awning you have, you may be able to remove the motor from the tube and install regular torsion springs and a manual arm kit to get the result you want. Look at Fig 8 and 9 of this link. Doug
http://www.primetimerv.com/download/ComponentManuals/Awning-Manual-A%26EDometic-UserGuide.pdf
38,766 PostsLatest Activity: Jan 10, 2026
