pnichols
Nov 06, 2014Explorer II
I'd love to switch to that Rickson setup on our lightly loaded 24 foot E450 Class C for more rugged tire availability (Load Range G) when off paved roads! Too much $$$, though.
The trouble with those Michelin Steel-Belted XPS Rib commercial tires is their tread - it's only a smooth highway tread.
One heavy Class C poster in these forums has stayed with their stock 16 inch rims, Load Range E tires, and 80 lbs. of pressure ... BUT merely went up in size to 235/85R16 tires. This tire is rated for more load capacity with no rim change or pressure changes required - plus these tires provide a bit more road clearance (due to their greater diameter) to better protect low points/items on the motorhome and less rear end scraping when entering/exiting parking lots.
