Gjac's avatar
Gjac
Explorer III
Apr 04, 2015
Ride Height on Gas MH's
I have been looking at gas MH's 2006 and newer and have noticed a lot of variance in the ride heights between MH's and from side to side on the same MH's from the rubber bumper and upper spring set on the front ends, mostly on the Fords. Does anyone know what this dimension should be for both the Ford and Workhorse? Workhorse seems less than the Ford from what I have observed.
  • Unless they are airbag suspension, which will maintain a constant dimension, sprung chassis will vary as a function of load.
  • Both Ford and Workhorse offer several chassis models and each has different ride hight specs respective to that model.
    Side to side there should be no difference on either, something is wrong.
