bobndot's avatar
bobndot
Explorer II
Jul 14, 2018
Ride/handling upgrade - E450 / 158" wheelbase
Am I correct on my thinking ?
I would think with the correct alignment, rear Sumo's for ride plus the rear sway bar would be a good bang for the buck and should offer the E450 a decent ride and crosswind/bow wave control.
RE caster :
Due to the location of the rear compartments (rearward of the rear axle) does the weight of stuff carried in the rear compartments come into play in the shorter wheelbase models ? (158" WB models)
When riding on the newer 2017/2018 E450's in a shorter 24-25 ft unit, that sits pretty much level all loaded up, what would the caster be set at ?
  • My light E450 (door sticker says 9900lbs empty) does indeed ride hard. Actually drives better with a heavy enclosed trailer hitched up. I have done some chassis add-ons like a Hellwig front sway bar, and originally Bilstien shocks all-around. I was not happy with the floaty low-speed valving of the digressive Bilsteins, and replaced the fronts with a pair of Monroe Magnum RV shocks, which were silly cheap and being a consistent firm shock way better. After 7 years the original steering stabilizer got swapped for a parts store Monroe unit too. I also just replaced the OEM Michelin LTX's with Coopers, not really wanting to pay the Bibendum tax. So far so good there too after 3500 miles. It generally drives pretty good for what it is.
  • Rob, you might want to try a set of Koni FSD shocks in the rear, like I talked about earlier in this discussion.
    They sure took a lot of the sting out of my E450 24 footer's pounding in the rear.
  • Have a 23 foot CoachHouse on an E450. Totally replaced rear leaf springs with Reyco Granning air suspension. Also added Koni FSD on all four corners. Pretty expensive but worth it to me.
    Huge difference in ride.
    Oldusedbear
  • That non-slide Coach House Platinum 220 on the E450 chassis is a sweet rig.
    Having one of those converted to 4X4, with slightly larger tires, and a small amount of lift would really make a comfortable way to camp in resorts or explore and camp off highway. The only downside I can see is that the 220's tanks are a bit small.
