bobndot's avatar
bobndot
Explorer III
Jul 14, 2018
Ride/handling upgrade - E450 / 158" wheelbase
Am I correct on my thinking ?
I would think with the correct alignment, rear Sumo's for ride plus the rear sway bar would be a good bang for the buck and should offer the E450 a decent ride and crosswind/bow wave control.
RE caster :
Due to the location of the rear compartments (rearward of the rear axle) does the weight of stuff carried in the rear compartments come into play in the shorter wheelbase models ? (158" WB models)
When riding on the newer 2017/2018 E450's in a shorter 24-25 ft unit, that sits pretty much level all loaded up, what would the caster be set at ?
  • bobndot wrote:
    .... that sits pretty much level all loaded up, what would the caster be set at ?
    My guess, if the caster is still the way it left the factory AND it is level fore and aft....best guess +4.0 to +4.5.
    That is based on 1 Degree nose down being +3.25 degrees.
    This is a krap shoot guessing game that comes with no guarantees.
  • The 158" wheelbase on the E450 chassis implies a small Class C?
    If this is the situation you're interested in:
    We have a 24 foot Class C on a 158" E450. Since day-one, the only downside to it's handling or ride had been up/down pounding in the rear on highway cracks/potholes from it's too-stiff rear leaf springs (but I wanted the overkill E450 chassis for several reasons).
    It came stock with front and rear sway bars and a front steering shock. The sway bars and stiff springs - combined with it's wide rear dually stance - provides superb crosswind, highway curve, passing trucks, and roadside curbs/dips side-ways force stability. It "drives like a van", with one-hand steering being easy when safe to do so.
    I've since drastically reduced the up/down pounding in the rear by some time ago having a mechanic install Koni's automatically adjusting FSD (Frequency Selective Damping) shocks in just the rear. The front shocks and front steering shock are still the originals after 12 years and 70K+ miles.
  • I don't think the Sumos are going to be of any benefit unless the rear springs are overloaded. The rear of a short E-450 is pretty stiff and harsh. An upgrade to the front sway bar would probably more beneficial than upgrading the rear sway bar. Get as much caster as possible on the passenger side and maybe a quarter degree less on the driver side. You won't be able to get too much caster.
  • If you are looking to buy new why not look for one built on a Chevy Chassis you wont have any of those problems and don't have to spend a lot of money to get to handle correctly :B
