My 2014 35ft Itasca leans to the right. Trust me its not a weight issue unless it came from Iowa that way. Do others have that problem? Will air bags fix the problem? Front or rear? Thanks
You have to know your left v. right weights to ensure it's balanced. If it's not balanced, my best guess is your springs are collapsing on the heavy side. Check that side closely to see if the mfgr. put in blocks to compensate for lean when it was built. Either way, get it evaluated at a truck spring shop to possibly have replacement springs installed.
