My 2014 35ft Itasca leans to the right. Trust me its not a weight issue unless it came from Iowa that way. Do others have that problem? Will air bags fix the problem? Front or rear? Thanks
John, you really should get at least side to side weights before and after leveling, to make sure you aren't making your MH a danger to drive. If one side is a lot heaver than the other, it could be very snappy to turn one way or the other.
