My 2014 35ft Itasca leans to the right. Trust me its not a weight issue unless it came from Iowa that way. Do others have that problem? Will air bags fix the problem? Front or rear? Thanks
I had the same issue on a brand new 2010 fleetwood storm. The dealer measured the lean and it was out beyond the specifications. They ended up puting metal shims on the passenger side rear axle I believe. Since it was under warranty it was covered.
