- Chum_leeExplorer
hl remington wrote:
RM 2652 Dometic 3 way has this part, Heat Tec thermotechnik Gmdh type P-818.Does anyone what it is for.
Thank's HL Remington
https://www.fourwh.com/NewDometicRefrigeratorManual.pdf
Chum lee - Old-BiscuitExplorer III
hl remington wrote:
Thank you Old-Biscuit for the exploded view,its part number 97 Reignitor.
Enblethen, thank you and yes it is a 3 way in a Roadtrek Simplicty
Wildtoad thank you for your information
HL Remington
Glad you have it identified
But you need to recheck Model Number OR explain what you mean by 3-way
Dometic RM2652 is 2-way only....120V AC electric element OR Propane
3-way would be 120V AC electric element, Propane & a 12V DC electric element (2 heater elements on boiler stack.....plus a 30A DC fuse on circuit board) - hl_remingtonExplorerThank you Old-Biscuit for the exploded view,its part number 97 Reignitor.
HL Remington - wildtoadExplorer IIAccording to my manual the RM2652 is only a two way. AC and Gas. It does require 12v for the controls though.
- Believe it is a thermal fuse. Some were installed during the recall of stack fires. My Dometic has one, but 3 way has two mounted in the stack behind the shield.
It should have continuity if it is good.
Are you sure it is a 3-way? - Old-BiscuitExplorer IIISO what does it look like?
Where is it located?
Electric heater element....AC or DC
Thermocouple device
ID the item/component from this exploded view link
38,782 PostsLatest Activity: Sep 10, 2026
