gerrym51 wrote:
Its an entire system. Roadtrek has a "full E-trek package and a partial e-trek package.
the full package is underhood generator-8 agm 6 volt batteries-5000watt inverter/charger-and solar panels. i suspect the underhood is a high output alternator but i don't know.
the key thing i that they have developed a contolling device that enables maximum battery charging from multiple sources.
the partial package is underhood generator-4 agm batteries-2500 watt inverter/charger and the special contol package. solar panels are an option.
Full e-trek on e-trek and CS adventurous as an option-partail on most of the other models
all these models with these packages require spwcial wiring and controllers developed by Roadtrek-they don't give out all info
thats all i know-you'd have to go to thier site and research
Are you sure it's the same on the Chevy Chassis 210? I don't see where you'd put so many batteries, or the solar. But I do see an option for the underhood generator.
