qhor's avatar
qhor
Roadtrek 200 handling & dumping
How is the handling of the Roadtrek 200? If I am not mistaken, the wheelbase is shorter than the Express 3500. Does it make a big difference, or is it still typically GM?
I have not been able to find pictures or references to the dump system or the pros and cons of it. Is it the "connect the dump hose to a solid pipe" or a snake type system with a permanently attached dump hose? Or some swing out system I have seen before? Or some derivative of one of the above. I understand that after 2004, a macerator was used.
Thanks for any info.
Barry
  • I believe the RT 200 is a Class C rather than a Class B, built from a cut away chassis.
    Nick
