mrlandlord wrote:
They are putting the batteries next to the inverter underneath the couch in the back of the RV. I am getting an external Stowaway2 storage box to compensate for the loss of storage due to the batteries. The batteries are 22"L x 13"H x 4"W. So that times 4 takes up a lot of space.
Let me see if I understand, your adding 524 lbs of battery behind the rear axel, and are going to add a Stowaway carrier, and your dealer told you this was a good way to go. If he told you that, I would then read my extended warranty very carefully. He's already given you misinformation about cycling the batteries.
It's your van I will butt out.
