NoVa_RT's avatar
NoVa_RT
Roadtrek Refrigerator - Blinking Control Panel
The Roadtrek's Dometic refrigerator was working fine on AC, until the middle of last night when I woke up to the control panel blinking. Couldn't get it to work at all on AC, and on DC the control panel lights would start blinking after a minute. The manual doesn't address this, so I shut it off, figuring the few things in there would be OK until morning,
No better luck this morning, although it looks like it may be running OK on propane, which I normally don't use when I have electricity. Anybody had this problem or have thoughts on what might be the cause?
  • Are you parked level?
    I'm within the center bubble both front-to-back and side-to-side, so I don't think leveling is the problem. Not really sure I'm getting much cooling on propane, either, although it was probably more like afternoon by the time I gave that a try & just turned it up to a higher setting half an hour ago since I wasn't sure I was getting more than the residual cooling from yesterday. The control panel is working normally on propane, unlike the blinking on DC & not lighting up on AC.
