Road-Trekker
Nov 10, 2017Explorer
obgraham wrote:
With that adaptor in hand you'd still have to shinny under the rig, unbolt the cleanout, and try to avoid a faceful of "stuff".
I don't know how his RS is setup, on my Agile, the clean out is within reach under the passenger side of the van, no need to crawl under. Just make sure the waste valve are closed before you unscrew the clean out plug, a glassfull of "stuff" is expected to freely drain from it' just open it slowly and let it trickle till dry...but I must say I have never used that emergency drain thru this years.
I've seen someone added an extension and a waste valve there, but it will be too low to the ground and will be prone to damage from road debris...just my thought.
