- ryegatevtExplorer IIOur '05 210 has the original macerator (and hose!); both still functioning fine. We're careful what goes in our waste tanks - no hair or garbage and plenty of water to keep things fluid. I believe 2005 was the first year for the macerator as standard equipment. After witnessing a couple of guys losing control of their Class A gravity dump hose in the middle of the dump station we were happy to finish up quickly and get pout of there before the mess spread our way!
- TinyoneRVExplorerI have an 04 Roadtrek that has been retrofitted with a macerator. Pretty simple concept; the macerator pump is placed at the end of the slinky hose and slides back up into the 4" pvc pipe. When winterizing I remove the pump and make sure there is no water left in it that can freeze and crack the housing. In an emergency dump situation, I can just remove the pump and I have the slinky back for dumping. The macerator is so convenient, it would be quickly replaced if it quit.
- Arizona_KidExplorer
bob_nestor wrote:
I thought the macerator was a great idea when I bought my Roadtrek. I've changed my mind. The impeller blades in the pump are made out of some sort of rubber that doesn't last all that long. Mine stopped working and of course I had a full tank I wanted to dump. Fixing it required removing the pump and rebuilding the impeller. Not a big cost if you do the work yourself, but not all that easy given the tight clearances. Not a big fan of having a full tank of waste overhead that's within a foot of my face as I'm removing some of the plumbing on the outlet side. LOL
Anyway, my next RV will not have a macerator on the dump. I'll use plain old gravity. I'm also tired of the misreadings on the gauges so I'll be looking for external sensors and a black tank flush feature.
I used my portable for years, and never had an impeller problem. - Arizona_KidExplorer
wincrasher65 wrote:
Seems like a waste of money to me, as well as unneccesary complication and future maintenance issue. If it will drain by gravity, why would you need a macerator?
2 reasons, One, many dumps at campgrounds are too high to use the gravity dump, and 2 with the Macerator you can pump uphill to any clean out. Try doing that with a gravity system. - bob_nestorExplorer IIII thought the macerator was a great idea when I bought my Roadtrek. I've changed my mind. The impeller blades in the pump are made out of some sort of rubber that doesn't last all that long. Mine stopped working and of course I had a full tank I wanted to dump. Fixing it required removing the pump and rebuilding the impeller. Not a big cost if you do the work yourself, but not all that easy given the tight clearances. Not a big fan of having a full tank of waste overhead that's within a foot of my face as I'm removing some of the plumbing on the outlet side. LOL
Anyway, my next RV will not have a macerator on the dump. I'll use plain old gravity. I'm also tired of the misreadings on the gauges so I'll be looking for external sensors and a black tank flush feature. - wincrasher65ExplorerSeems like a waste of money to me, as well as unneccesary complication and future maintenance issue. If it will drain by gravity, why would you need a macerator?
- gerrym51Explorer II
NCWriter wrote:
I think Davydd put a similar system in his class B, a custom-built Advanced RV.
I'm a fan of gravity vs macerator, so I think the dual system is a great idea. Pick the one you like, and when the macerator has a problem, you've got a backup.
first van below 150,000 dollars with dual system :B - NCWriterExplorerI think Davydd put a similar system in his class B, a custom-built Advanced RV.
38,771 PostsLatest Activity: Apr 15, 2026
