navegator
Dec 09, 2012Explorer
If the unit has a viscous fan clutch, and the clutch has gone south the fan will block air from passing through the radiator.
At freeway speeds the fans with fan clutches actually turn backwards in the air stream, and you will see the temp go up if the fan is actually turning with the speed of the engine, the fan is runing to slow for the air coming into the radiator area, and actually creating a wall or air in front of the radiator.
navegator
navegator
38,776 PostsLatest Activity: May 15, 2026
