jimmyfred
Aug 12, 2016Explorer
...........Take a water hose with squirt nozzle attached , remove the top cover , with the unit running........spray the cooling coil with water from a few feet away ! IT , WILL NOT hurt any part of the unit !!!!! USE water ONLY.........compressed air can bend the small aluminum vanes but water should not . Water should remove a lot of the accumulated material that is clogging UP the voids that normally allow air to circulate through them . , jf
38,763 PostsLatest Activity: Dec 05, 2025
