pianotuna
Jul 20, 2017Nomad III
Hi j-d,
I successfully run one 13500 on 15 amps. By definition 30 amps is twice as large, therefore running 2 13500 on 30 amps may actually be easier than running one on 15. The compressor start ups are not likely to coincide.
It is true there won't be a lot left over for other purposes. So I would do as I have done with my water heater. I added an additional shore power cord with male and female plugs so I can switch back to the OEM wiring in 20 seconds if I so wish.
The real risk is low voltage (brown out). That can be solved by adding an autoformer.
38,774 PostsLatest Activity: Apr 26, 2026
