MobileBasset
Apr 15, 2017Explorer
When you are leveling the RV give it a small tilt to the direction you would like it to drain. When it is collecting on the awning pull one of the outer awning corners down and tighten the arm in that position to allow the water to drain off. You should not let water collect on the awning.
I have a channel on the roof edge of my RV that sends all the AC water along to the outer front or rear corners depending on how my unit is leveled.
38,769 PostsLatest Activity: Apr 24, 2002
