Old_Crows
Apr 18, 2017Explorer
Well Bud, welcome to the wild and woolly side of RVing.....
RV Camping Law # 17. No matter how you level or adjust your RVs stance, the AC condensate will run off onto the awning and/or drip off above the main door and onto you and the steps. It just IS.
(Personally, it's the wee people and fairie people..... they are directing the water toward the door way..... )
Seriously, it's just what happens. I've no idea why but three RVs tell me it's the way things are unless you lay the camper on it's side.
The suggestion to 'pitch' the awning is good but if your Navion is like my View, it has a 'self erecting' awning and there's no struts to adjust or trim. It just cantilevers out. If water collects on it, just retract it a bit and let the water drain off. The bigger issue is not to store it a long time with a wet awning. That will get oooogly pretty fast.
If your Navion is fitted with at Coleman Mach 8 AC-Heatpump, the condensate drain is not as on older ACs where the stuff sort of drained out from a hose or couple holes in the floor of the AC unit. The Mach 8's expansion coil sits in a molded resin tray and is side to side in the unit. At either side are wells about the size of a cigarette pack. Condensate drains from under the coil into these wells. Wells have drain holes and the condensate drips directly on to the roof from either side of the AC. The holes are pretty big so you don't have to worry about clogging. All this mess is covered by the bonnet.
The good news is: condensate production tells you that the unit is working as designed.
38,769 PostsLatest Activity: Apr 24, 2002
