the_silverback
Dec 27, 2015Explorer
roof air failures
In just the last 3 months 7 of my friends have their roof air units fail. 4 of the RV's were new. Has there been a design change? Have any of you seen a similar situation? Seems weird to me.
the silverback wrote:
There is something bad going on!! We are wintering in FL. Just today 2 of my neighbors had their AC units fail. There were 2 different service trucks here at the than the same time. I think this could result in more failures than the refrig. problems. These failures are in addition to the ones in my pervious post, and just the ones I know about.
Hikerdogs wrote:
As someone who has had an AC fail I can also say GOOD LUCK getting anyone to repair it. We have a 2013 Winnebago Adventurer with 2 RVP roof air conditioners. They have less than 50 hours total runtime, and probably less than 5 hours runtime in the heat mode. The front AC will no longer switch to the heat mode. It has either a bad switching valve solenoid or a bad switching valve.
We took it in to the factory service center in Forest City IA and the only the only repair they would do is replace the entire unit for $1,600.00. We declined the repair and contacted our local authorized RVP facility to see if they would be able to repair the unit. They gave us the same answer.
The next step was to contact RVP to see who would be able to repair the unit. Again we got an almost identical answer. The only difference being that if in fact it was the solenoid it could be replaced for around $30.00. If it was the valve itself they recommended replacing the entire unit.
The justification all around was that replacing the valve would be more expense than the unit was worth. The valve itself costs about $200.00. The estimated labor to replace it would bring the price close to half the price of a new unit.
It's hard for me to believe it would cost $600.00 in labor and materials to replace a switching valve. It's even more difficult to believe that no one saw anything out of the ordinary with an air conditioner only having a 50 hour service life.
chuckftboy wrote:
I work in the air conditioning field and its nothing more than the units are being built as cheaply as possible. Most of the electrical parts are foreign made and the copper tubing is very thin. Very few compressors are made here anymore.
We live in a disposable world now so any failure in warranty and they just replace the unit. Its now cheaper to build a new one than pay the labor to make a warranty repair.
The cheaper they make them, the more failures we'll see.
