choppermtn
Aug 13, 2019Explorer
roof air
I need to replace my roof air . I have replaced one before but this one is ducted and has no access from the inside of coach How do I remove the roof unit to replace it?
dougrainer wrote:Chris Bryant wrote:
Yours is going to take a very specific replacement, depending on what you have. It is lag screwed in, instead of bolts. Here is a picture from one of the training power points showing a Newmar install.
NOTICE that gasket that goes between the 2 roof holes. THAT gasket is critical for correct operation. It separates the Intake hot air from the cold exhaust air and if not installed or installed incorrectly, you will not get adequate cold air output. The Lag bolts are installed into a wood/aluminum backer plate. Just make sure you measure and drill the 4 holes in the New AC mount pan, exactly where the original ones were, Do NOT over tighten the lag bolts or you can strip them out of the Aluminum plate. Doug
