We have two roof air conditioners, Dometic, worked well while in Florida, came home in January did not use until this week, 7-12. When we started them up, outside temp high 80's to 90's there was a o...
How ofter do you clean the filters. They should be cleaned every month when in use. The dirt thay gets past them will make the evaporator coil smell pretty bad after a short time.
