infogeek
11 years agoExplorer
Roof Leak
Been chasing a roof leak for a while. First seemed to be some old patches that had failed, cleaned off and redid. Seemed to work. Then leaking again. Seemed to be around the fan, recaulked and seem...
infogeek wrote:
RV guy was just here. Can't see any obvious leaks but says the rubber is checking. Thinks it's getting porous and should be replaced. He thinks scrubbing and prepping to apply a coating will make it worse, and isn't sure it will stick (like duct tape on a powdery surface is how he put it). I did try some Eternabond at one point for an emergency patch and that did not stick despite cleaning and rollering it hard, so maybe he has a point there.
RV Daytrader: yes, installed roof vent/fan.
