BigRabbitMan
Feb 07, 2015Explorer
zippyphil wrote:
I will bring new life to this topic, with this, can you use a vinyl wrap company to seal the roof? I imagine there would still be prep work but would the vinyl be thick enough and durable enough? I would like to think this (vinyl) would fix many leaks around the vents. My plan would be strip the roof of vents, ac... smooth anything out an then wrapping the roof first then the rest of the RV. Thoughts?
-Phil
A vinyl wrap will not work and will cause a big problem as the vinyl only lasts a year or so before it starts cracking. After a few years of sun, it forms alligator skin like cracks and you will have a very expensive job of removing ALL of the vinyl wrap. Also it does not flex so at the coach seams it will crack quickly.
