JulieB888's avatar
JulieB888
Rubbing Alcohol-type Smell
Hello kindly folks,
I got a problem. There is this smell that comes and goes. At first i though that it was gasoline so I checked for a leaky gas tank/lines, but there was no leak and I realized last night that it isn't exactly gasoline smelling either. It typically comes from the rear of the vehicle, often when it hasn't been driven in a few days, but sometimes after driving. However I have smelled it up front a few times when I was driving as well. Usually its very mild but last night it was so strong that i couldn't sleep in the rig. I have sniffed around quite a bit when it has come and it seems to be coming in the heater vent on the inside and from a similar place on the outside. The heater has been broken for years, the fan works but no heat comes out. But I am wondering if there are any fluids in there that would produce a rubbing alcohol like smell. Any ideas?
Much appreciate your help
Julie
By the way it's a 1992 Roadtrek on the Dodge Chasis
