Executive wrote:
I would step it up to 10ga wiring and use a 20amp circuit in the trailer. You could follow the setup wa8yxm gave you above, but if you're thinking of using it as a workshop type setting, I'd go the higher amps. You'll need them with an air compressor....Dennis
It's just a little compressor. It runs off my 15 amp breakers at the house. I'd use it just for flats on the motorcycles and just in case the rv needed air. Other than that I'd just run rope lights in the trailer and a very small motorcycle battery charger.
